Hello,
I am designing a project of home automation where i am using Arduino YUN board for the automation purposes. I want to design a circuit so that my relay can be controlled through two ways.. Like my project will be comprising of Auto/Manual mode. When i go in manual mode the lights can be turned on manually by using switch buttons. But when i go in Auto mode i want my lights to be turned on only if the arduino sends a signal to turn it on. Even if the user manually turns on/off the switch button the light wont turn on/off.. It can only be controlled through Arduino. Personally, i designed a solution to use two relays for controlling one light, but i am not sure and dont want to use two relays and want to know if theres some way i can design it using a single relay.
Feedback will be appreciated.
Thank You
Thank You
