Drive for paralleled FETs
John Smith
I'm designing an H-bridge to drive a 12V DC motor. I am putting 2 FETS in
parallel for each of the 4 corners of the bridge. I will be using an IR2104
driver.
The question is, should I tie the gates of each pair together and drive them
through a common resistor, or should I provide a separate resistor for each
FET? Either way, I would appreciate knowing why that method is preferred so
that I can learn from it.
Any guidance is greatly appreciated.
John
F
Fritz Schlunder
driver.
John
Greetings.
For best reliability and performance it is normally recommended to use two
separate gate drive resistors. For more reading on this subject I suggest
the following:
http://www.irf.com/technical-info/appnotes/an-941.pdf
K
Keith Buck
You need both, as the parasitics need stoppers at each gate (these are
generally low value, i.e. 10 ohms or less depending on transistor size) Then
you need a common drive circuit with possibly 2 resistors an a diode. This
lets you adjust the rise and fall times of the gate voltage separately.
Regards Keith Buck
