There seems to some decent isolation on the PCB between primary side and secondary side. That's good.
There seems to be an overvoltage protection at the input side. That's good, too.
The quality of the transformer's construction cannot be judged from the photos.
The quality of manufacturing is poor. See for example how the wires are attached to the PCB:
Instead of fitting the wires through the holes and then soldering them, they are soldered flat to the PCB at the bottom. This is not good practise.
Note that there is no protective earth and no strain relief for the mains wires. This power supply needs to be housed in a non-conducting housing (as the original plastic housing). Care has to be taken that even in case one of the primary wires comes lose it cannot touch the secondary side. The original housing may (or may not) have the required separators built in.
My opinion: If one is not an expert in such things it is better to keep this kind of power supply closed in the original condition. By opening the housing you not only lose what litte warranty there may be but also risk reassembling it incorrectly which may directly lead to latent danger.
