E
Efskeff
Hi all,
I recently bought a "pure" sine wave inverter to try to set up backup
electric power for my gas-fired central heating boiler, in the event of
an electrical blackout.
Boiler normally uses about 60W electric power for air fan (induction
motor), two solenoid-operated gas valves (pilot and main) and a spark
igniter. Inverter is 150W, supposed to supply surge to 450W.
It runs the ignition sequence perfectly - air fan starts, pilot gas
valve opens, spark ignites pilot flame - then stops; main gas valve
fails to open, no ignition of main burner.
Digital multimeter reads no great voltage drop as main valve "tries" to
open, slight current surge to about 300mA before settling back to 240mA,
as it does on mains supply.
Does anybody know if "pure" sine wave inverters are really pure, or do
some of them have impure thoughts, i.e. harmonics that might interfere
with the operation of the main valve solenoid?
Or is some other reason likely to be the cause of the trouble? I'm
unfamiliar with the quirks and foibles of inverters, so I hope there's
someone out there who is more experienced in them than I am.
Thanks!
Efskeff
Thanks!
Efskeff
