saman said:
I'm designing a FRA(Frequency Response Analyzer). Maximum frequency that
I need is about 1MHz. Now for multiplication of response wave to
reference Sin(a) and Cos(a) I have two ideas, either use a very fast
MDAC which I couldn't find a suitable one till now or use an analog
multiplier.
Your helps are welcomed
If I were you I'd use a pair of double-balanced diode-ring mixers e.g.
Mini-Circuits SBL-1 or one of the newer siblings. Generate sin/cosine
signals (e.g. I and Q), amplify, feed through a 50-ohm attenuator pad
(say, 6 dB or so), and into the "LO" ports of two SBL-1 mixers.
Similarly, amplify/buffer the incoming signal, split it and pad it,
and feed to the "RF" ports of the two mixers.
Feed the "IF" port of each mixer to a 50-ohm buffer (e.g.
grounded-base amp) and feed it through a diplexor/filter which has a
bandpass as wide or narrow as you wish, then measure the resulting
output.
[The padding and buffering is required to ensure that each of the
three ports on the mixer "sees" a 50-ohm impedance to any signals
coming out of the port - this is necessary for proper operation.]
If I were doing this, I'd consider using an IF of 3.579545 MHz, as
this would allow the use of an inexpensive filter using cheap NTSC
colorburst crystals (I think there probably some resonant transformers
pre-wound for this frequency, too), and it's high enough above your
upper frequency limit that a simple low-pass filter prior to mixing
would eliminate any image problem.
I imagine that you can do this with just one mixer and one LO
signal... I don't think you need the full quadrature pair in order to
simply measure the signal amplitude.
