I have a 9v battery hooked up to 2 joysticks which need about 4v each. I have the power wires connected to the breadboard positive strip which is connected to the 9v battery's positive terminal and both ground wires connected to the breadboard negative strip which is connected to the negative battery terminal. Will the joysticks receive the full 9v (like in a parallel circuit) or will the volts be split between the joysticks?
