Hi David,
On 4/13/2012 5:22 AM, David Brown wrote:
[elided]
That's maybe okay if the multimedia is quite small, and tightly tied to
the documentation.
Yes. I'm not intending to include "how to videos" or lengthy
audio excerpts. Rather, things like:
- this is what the vocal tract looks like AS this sound is made
- this is how a 2D curve changes over time under this influence
etc.
Things where you want to consult the text *as* you are viewing/hearing
the presentation. And, be able to easily replay it, etc.
But if it makes the pdf documentation much bigger,
then personally I would prefer the pdf file to be separate.
I haven't actually tried anything like this to tell. The nearest I have
come is using pdfLaTeX with attached files (program code) - that
certainly worked without problem, and the program file can be saved
separately from the pdf file.
I know I can extract photos embedded within PDF's. Not sure what
the "free" tools can do.
(I've also learned to *crop* photos before inclusion into the PDF
since cropping them *in* the file still leaves the cropped portions
available when the photo *is* extracted!)
But I /have/ seen Adobe's software making a complete hash of generating
pdf files, such as making pdf's that are orders of magnitude bigger than
necessary, or that only work on some computers or some readers.
I've never noticed a big difference between file sizes regardless of
how the file was created -- but, that's been just text+images, up
to this point. I recall options to specify the PDF "level" to
generate the output format.
And, I've avoided the "non-Adobe" readers simply because everyone
*can* get Adobe's version without a financial commitment (and I
don't want to be dealing with XYZreader on BozoOS not being
able to read my documents, etc.)
Fair enough. But when giving suggestions for things to try, I don't
think it is appropriate to recommend commercial software unless I know
for sure that it is up to the job (and in this case, I don't know of
any). With free software (which I know to be good quality, and /really/
free - not adware, trialware, etc.), then I can suggest you try it out
and see. Maybe it will do the job, maybe not - but at least you haven't
wasted lots of money on it.
I'll look at what's out there.
The key point, of course, is that the results should be accessible to
anyone without having to buy additional software or be tied to a
particular platform.
Yes. Though not as dogma (if you can't view the documents on BeOS
you won't get much sympathy from me! :> )
If /you/ have to buy particular software, then I
expect it would be a small matter overall.
Agreed. Even if its not so "small"
Google for "pdfLaTeX multimedia" if you like.
OK.
As far as I understand it, you want to generate professional-looking pdf
files - and that means you need to have these features. A great many pdf
files - even those made with Acrobat - fail in this way.
I'm very good at generating content. What I need is to make sure
the content that I want to present to the user is accessible to
him/her -- without having them jump through hoops.
(documentation is supposed to make things *easier*, not harder!)
