L
laylow
I have two NOR latch circuits side by side.
The first NOR latch is set to Q=1
The second NOR latch is set to Q=0
A signal is sent simultaniously to reset the first latch and set the
second latch.
The outputs of both latches are sent to an AND latch circuit.
My intention is for the first NOR latch to reset before the second NOR
latch sets.
Will there be enough delay between the reset and set to prevent the
AND latch from setting?
If not, what is the easiest way to add sufficient delay to the second
NOR latches output?
Could I just use a slightly longer trace to the second latch?
I'm trying to keep the circuit as simple as possible so I would prefer
to not have to add some sort of delay circuit. If I do have to add a
circuit, could it be something simple that just uses some sort of
capacitor/resistor combination?
Thanks All,
Laylow
No email please, the account no longer exists.
second latch.
latch sets.
NOR latches output?
Thanks All,
Laylow
