Roger Bourne
Hello all,
Does anyone know if DDR SDRAM modules (or similar modulars) use
internal charge pumps (to boost up the power supply of core modules)?
The reason why I ask is that I am interested in DDR SDRAM's leakage
current values. Someone mentioned (in another ng) that there may
internal charge pumps. Hence, if there is a CP in the DDR SDRAM,
killing the clock and grounding/vdding all other data inputs will not
*make* the leakage current drop to the *correct* order of magnitude, if
the CP is enabled and has its own local (ring) oscillator. *Correct*
order of magnitude (for a typical IC) being sub-uAs.
If anyone knows of a typical value of the LEAKAGE CURRENT of DDR SDRAM
module, it will be much appreciated. In datasheets, I was only able to
locate the MAXIMUM INPUT LEAKAGE CURRENT parameter ([-5uA to +5uA]).
P.S If a DDR SDRAM DIMM has 184 pins and most of the pins are data
pins, then the TOTAL INPUT LEAKAGE CURRENT can accumulate up to ~920uA
(theoretically). This is a pretty impressive leakage conssumption! Can
this be rigth ?
Please advise
-Roger
this be rigth ?
Please advise
-Roger
