Hello,
I have made a project for controlling RGB flexible LED strip. It's a three channel DMX controller that i want to put to give some color to my business. It uses a PIC16F628A with a code that i downloaded from the web. It all works perfectly, the only problem is that when the outputs are low, the LEDs flicker a lot, the brightness is not stable. The potentiometer scale of the DMX table goes from 0 to 255. When I move the pot, from 0 to 50 i get the flickering and from 50 and up it's perfect. I have made many test and i know that the problem is with the ASM code but i don't know how to solve it. You can see the attached code.
Any help on how to make this work properly will be really appreciated.
Many thanks, Ana
Many thanks, Ana
