Hi Guys,
I'm hoping someone here can help as I have searched the web all night with no luck! I know absolutely nothing about LEDs but am determined to get this to work!
I am trying to make a remote controlled single 10W LED spotlight to put over my fish tank... I want this to be a controllable RGB light so that I can change the color with the remote. This will be purely for aesthetics and not to support plants/corals. I don't want to use the pre-made LED strip lights as I want it to be a single hanging fixture.
Right... So here are the components I have...
So, now my goal is to (if it's even possible) connect these 4 coloured cables into a single 10W RGB LED chip. I have bought the following two chips hoping one of them would work...
Will either of these chips connect to the 4 coloured cables? If so, how do I connect them? If not, what kind of chip should I be using?
Any help here would be greatly appreciated!
Thanks!
Tom
- Outdoor 12V Transformer Power Supply Adapter LED Driver IP67 Waterproof 10W - This is plugged directly in to the wall and outputs to the following controller.
- 18A Wireless RF Remote Touch Panel Controller For 5050 LED RGB Strip 12V Switch - The controller box then outputs 4 cables (red, green, blue and black), these would typically go directly into a standard RGB LED strip light.
- 10w Cree XLamp XM-L RGBW RGB White Color LED Emitter 4-Chip 20mm Star PCB Board
- RGB LED Light Bulb Beads 10W Lamp Bulb 1pc High Power Super Bright Integrated | eBay
Thanks!
Tom
