I don't make my own PCBs, but something I've not seen mentionned in the
laser toner transfer technique is that the paper backing for adhesive
labels is perfectly calandered (ie smooth) and will gladly release the
toner with just a bit of heat. The bonus is that this type of paper is
free. Just look out for the lines where the die-cutting blades cut.
Basically you just print on the smooth side and there you go.
I've used Corporate Express EXP00716 labels and made a test etching for
a mixer board. I think it went fairly well, but I never soldered to it.
(I just plop the parts right on the mixer, it works)
I believe the idea is that this paper won't grab to the toner
preferentially to the rougher copper surface.
Anyways I just thought I'd toss that out there. Do with it what you
will.
will.
