Hey guys, newbie here. New to the forum not electronics. I am more into DC electronics so I have a few questions about a diy multi bank battery charger I am thinking of building.
So I am going to use a 120vac to 15vac transformer to a 4 amp bridge rectifier. My question is can I power(for lack of a better word) multiple bridge rectifiers from a single transformer. That would allow multiple outputs to battery's. They would be connected in parallel from the transformer output.
Question 2: 15 volts is going into my bridge rectifier and the one I plan to use has a . 6 volt drop. Brings my dc output to 14.4. I need to bring it down .6 volts more. What should I use to do this? A zener diode? Or something else? Can someone recommend a part number. Also would I be better off dropping voltage while in ac or after the bridge rectifier in DC voltage.
3: could someone recommend a simple regulating circuit and how to tie it into my current circuit.
4: is there a way to control the amperage? If I wanted to charge at 1amp 2 amp or 4 amp? Or is this getting too complex for a novice like myself?
Thanks in advance
Thanks in advance
