Jon Slaughter
I have a remote to a tv that I would like to increase its distance by a few
feet. The system is Dish TV and the remote uses UHF. I have taken apart the
remote and it uses
http://www.analog.com/UploadedFiles/Data_Sheets/ADF7901.pdf.
Unfortunately its SMT so its going to be hard to mess with. I need to know
exactly what I can modify to increase the range from about 50ft to about
55ft. I don't even know if this is possible though.
I figured that if I increased the current through the antenna that it could
give it enough.
Whats strange is that having the remote at very specific points and at very
specific angles in the room will get the signal to the reciever. I do not
believe this is due to reflections or anything like that. Maybe the signal
is degraded by the long distance so much that it only works 1/100 of the
time? It has steadily gotten worse over time and I assume its cause of the
batteries.
In any case I'm wondering what you guys think I can do? Maybe run a few more
batteries in it? Increase the loops of the antenna? Change the power going
to the transmitter section?
I'm going to read over the datasheet and see what I can come up with.
Unfortunately I do not think there is going to be a simple of a solution as
I initially thought.
Thanks,
Jon
remote and it uses
give it enough.
batteries.
Thanks,
Jon
