Discrete JFET input stage for op-amps
alan
Hello,
I have heard this technique mentioned before to lower the voltage and
current noise of an op-amp. Can somebody point me to a schematic on how
to do this? I plan to use this in a high gain current amplifier, so
that means that the input will act like a virtual ground. It also has
to work down to DC.
mike
alan said:
Hello,
to work down to DC.
The Tektronix 490 series of spectrum analyzers use a biopolar superbeta
pair in front of a low noise op-amp in the YIG current source.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Johnson
Take a look at the schematic of the SSM2019 on Analog Devices website -
somewhat the same idea with bipolar devices for a 1nV Rt Hz opamp for audio.
bill.sloman@ieee.org
Farnell list four dual N-channel FETs. Only one - the Vishay U404 - is
a monlithic dual, while the others are pairs of chips mounted in a
common package, which works almost as well to minimise temperature
dependent off-sets.
National Semiconductor used to make a monlithic dual where the two FETs
were inter-digitated, which gave very good temperature matching (though
the drain-to-drain capacitance was a bit too high for good high
frequency performance) but I don't know a distributor that still stocks
them
The standard circuit uses a matched pair of FETs as a long-tailed pair
in front of the op amp. The current through the long-tailed pair should
be as high as you can make it - that means that the FET should be
operating with with the gate only slightly more negative than the
source, so that the gate-source diode is only just reverse biased.
The inputs to the op amp are then connected to the drains. The drain
resistors have to be chosen to keep the DC voltage at the inputs to the
op amp within the common mode range of the op amp, and then you have to
check that the gain through the long tailed pair is high enough that
voltage noise from the FETs is amplified enough to exceed the voltage
noise contributed by the op amp. Too much gain from the long-tailed
pair, and the extra phase shift it introduces may make the feedback
loop unstable = the frequency compensation buit into the op amp is
only designed to cope with its gain and phase shift - but if your
amplifier is to provide a high closed loop gain, this shouldn't be a
problem.
doug dwyer
alan said:
Hello,
how to do this? I plan to use this in a high gain current amplifier,
so that means that the input will act like a virtual ground. It also
has to work down to DC.
Not sure if you are asking for this; but Linear Tech returns time and
again to a discrete bog standard Philips high gm low noise fet auto
biassed by a following wide band low noise voltage opamp.
FET has a narrow vgs0 current range so easy to bias from a modest
supply, they always show it combining nVroot Hz and attoamp input useful
for diode or charge input.
alan
Thanks for the help, guys. I'll need to read H&H now to learn about the
various properties of JFETS, and maybe what to watch out for. I suppose
I can follow this stage with a low voltage noise high current noise
bipolar amp. Then I don't have to use a high gain on this input stage.
Should be possible. It is unlikely that you will be able to use low
enough drain load resistors to make it worth paying for a really low
voltage noise op amp like the Linear Technology LT1028 or LT1128, or
the Analog Devices AD797, whose input voltage noise (around 1nV per
root Hz) is about that of a 50R resistor. Even with the cheaper OP-27 -
3nV per root Hz - you will need a fairly high current FET to get the
load resistors down to the 400R which generates that much Johnson
noise.
The Vishay U404 I mentioned generates some 10nV per root herz with a
drain current of 200uA - you'd obviously use a higher drain current,
and probably a bigger FET, like the U430 or the U440 which Farnel also
stocks, to get something closer to the 4nV per root herz at 10kHz
quoted on the U440 data sheet for a 5mA current.
If you went for the U430 or U440, you'd need no more than a gain of two
from the dual FET stage for their noise to swamp the noise generated by
an OP-27 or one of its numerous equivalents - I always liked the Linear
Technology LT-1007.
