Jamie Morken
I have a power supply with some big 400Volt electrolytic caps with
100kOhm resistors in parallel to drain them for safety, I was wondering
if a d-fet could be used in series with the resistor so that once the
power supply is online, the d-fet could be turned off, to save power
by not having 1.8watts going through this resistor (100kOhm at 400VDC).
D-fets (ie. DN3765) are normally on switches, so once the power supply
goes offline, the caps should drain for safety. Is this a good way to
save power, also are there other ways to do this?
cheers,
Jamie
cheers,
Jamie
