I have two different power supplies that will power a fan (call one manual and one auto). The manual power can be turned on via a switch. I am using two Normally Closed relays on the Auto power supply so that when the switch is flipped for the manual power it opens the relay disconnecting the auto power
However in this set up when the auto power is on it runs through the fan to the switch power wiring and closes the relays!
I can either fix this by adding two more relays of the normally open kind on the manual power side. or isolate the manual power side using diodes.
My question is what type of diodes would I need? The Voltage that would pass through on the manual side is about 28 volts running at about 4 amps with possible 7 amps on start up. The voltage is we need to block would be the same.
Any other set up ideas would be appreciated !
