I
Ignoramus7040
Thanks to many people regarding your earlier advise on modifying my
TIG welder. The sequel to that saga is that the welder works and I use
it quite often.
Now I have a smaller modification to ponder.
After several unpleasant experiences with battery chargers (which did
not work) I want to try something different. My typical use of a
battery charger is to use it to replenish some battery that does a lot
of engine cranking.
I have a power supply that I am thinking should become my battery
charger. It is a PP-1104B/G. If you google for PP-1104C/G you will
find a description of a very similar power supply. It has a dual
range: 13-19 volts at up to 100 amps, and 26-39 volts up to 50
amps. It is a constant voltage power supply with no current limiting
other than built in breakers. I added a few not very relevalt things
to it (like handles for easier handling), but it has a few electrical
quirks that I would like corrected.
The first is that when it is turned off, it drains the battery (ie the
current flows "backwards" as opposed to current flow when charging)
and quickly consumes a lot of amps. It appears that adding a diode
with a small heatsink should take care of the issue.
My calculation is that at 100A, the diode with voltage drop of 0.7
volts would produce 70 watts, which is trivial to dissipate. I have a
number of suitable diodes and heatsinks. So, unless someone gives some
great reason why adding a reverse protection diode is a bad idea, I
will do it.
My second question is whether there is an easy way to add a current
limiting feature to this device, that is, make current limited to a
value set by a potentiometer. That would make it valuable for, say,
electroplating.
I read about current limiting today. The ones I read about were based
on the principle that there is a transistor in series with the load,
that basically acts as a variable resistor to limit current. That's
wasteful, but I can live with it, but perhaps there are more clever
schematics of a current limiting add-on. There is no space inside that
power supply to add anything, so any such circuitry would be in an
external device.
Any suggestions on more inteligent current limiting add-ons will be
gratefully appreciated.
i
it quite often.
of engine cranking.
will do it.
electroplating.
external device.
i
