I made a simulation in proteus VSM:
The AA119 is supposed to be a germanium diode while the 1N4001 is a silicon one.
What's the concept behind these readings?
Why is there a voltage across the two diodes on the left even if no current flows, and what is behind the ratio at which they are following everytime the voltage across them changes?
Why is it that changing the series resistor changes the voltage levels, I thought Silicon has a 0.7 drop and Ge has a 0.3 drop?
and in the middle circuit why does the Ge diode have 0 V across?
This is not a homework assignment, but rather I am just trying to iron out my theoretical misconceptions and I could use some helpful insight because I have had conflicting answers from different people about this.
