Dimmer won't work when connected to power inverter
Chuck
I successfully tested an 18ft long section of rope lights (Hunter brand) and a 3-stage touch dimmer in my house before taking out to install it in my RV. After plugging it into my 12VDC to 110VAC power inverter it just has one brightness level which is maximum brightness. Once its on, I can't turn it off again without unplugging it. I tried using a standard incandescent rotary dimmer with the exact same results. Why is this happening?
Why does it work properly on 110V 60Hz household current but not with the power inverter? Thanks.
Don Kelly
Baron
with the power inverter? Thanks. ----
The waveform from the inverter may not be appropriate to a device
which expects a sinusoidal or near sinusoidal wave. Your inverter
which is probably intended for resistive loads (or loads such as a
TV in which conversion to a different level or levels of DC takes
place) may not provide a true sine wave and possibly even gives a
square wave which makes the dimmer simply turn on fully no matter
how you set it.
Don Kelly [email protected]
remove the X to answer
Yes this is the reason. The inverter outputs a square wave. You could
try reducing the 12 volts supply to say 10 and see if the change in
output is enough. But you may have to watch for overheating the
inverter. Another way would be to filter the inverter output but you
will need to have some fairly big chokes to handle the load.
Chuck
Thank you both. I knew it was an issue of this sort but I didn't know what.
Chuck
PeterD
Yep, it won't work with an inverter. Now you know! <g>
Sine wave for household current, square wave from the inverter. There
is no slope on the square wave to get partial voltage, so no dimming.
There are 'tricks' you can do to make it work somewhat, but I won't
get into them, and they are much too much work to be practical
(basicalyl converting the square wave into a more sine wave form.)
cadman
You could maybe fiddle with the inverter to try to sine up the
waveform.
A capacitor across the transformer would help.
The value is down to trial and error.
F
Farticus
What about rectifying the 110V AC and using a DC/PWM dimmer?
JeffM
was: Dimmer won't work when connected to power inverter
Piss off, you lazy bastard.
F
Farticus
Thank you Jeff, you are so kind and good hearted.
What a lovely person you must be.
