I thought I would post this on here as I was not sure how many of you guys seen this brand before and thought I would share this.
I find it kind of funny that the Bonkote in the top link is really expensive and plus it's used and the guy is asking 99.99 and yet the unbranded version of the same unit can be found on ebay for 20 bucks.
If you look at both links the second one is clearly 100% the same as the Bonkote one other then the color and the fact it is a dual channel.
I thought I'd get one for my Hakko FX-888D seeing that my voltmeter that had a really good built in thermometer just died,I have another cheap Voltmeter with a built in thermometer and I'm going to check them against each other to see how close they are.
Has anyone here used either of these to measure their Soldering Irons tip temp,I had problems with a Station I had a few years back and needed to re-calibrate it as it was out by 95 degrees on the low side.
http://www.ebay.com/itm/BONKOTE-MCA...ature-Meter-0-1000-C-W-K-Probe-/182246979626?
http://www.ebay.com/itm/Dual-Two-Ch...09dbf6&pid=100005&rk=6&rkt=18&sd=331940775068
