Digital Filter Design Approach
Hello,
I'm reading the attached pdf file. I don't understand the design approach (yellow-highlighted). Could you please explain?
Thank You,
BlackMelon
  • Design of Digital Filter on ECG Signal Processing.pdf
An ECG signal has DC baseline drift caused by muscles in the patient and mains hum interference picked up by the patient's body. Then most ECG circuits use the common-mode DC and AC interference signal produced by the instrumentation amplifier IC, invert it and feed it to the patient (usually to the right leg) to cancel the interference. Then a filter might not be needed or it can be simple.
