Muriel said:
Well, I actually did not understand your schematic circuit... Could
you give an example to make things clearer?? Well, I had my classes of
algebra yet, and eingenvectors are not monsters to me (at least, I
think!!
That gives us two ways to proceed. Lets do the vector
space stuff first. By the way, I am a terrible two
fingered typist, so if something doesn't make sense,
there is a good possibility that I miswrote. Sometimes
I come across like I have rabies or some dementia.
Well, let me get into the Eigen vector first.
I think others have set up the physical situation.
Just to repeat, there are three "conductors". Two
are the intentional transmission line. The third
is called ground or return or neutral.
V1in -------------------------------- V1out
V2in -------------------------------- V2out
ground -------------------------------- ground
"Ground" might be an actual intentional conductor
that runs along with the other two and it might be
a large conducting plane of copper and it might
just be the Earth itself and in some cases we
take ground to be a conducting sphere with infinite
radius of which we are inside, or as I like to say it
the "Rest of Creation" (the ROC). For convenience,
lets say that our intentional pair has an input side
(the left side) and an output side (the right side).
In general, V1out depends on both V1in and V2in.
Likewise, V2out depends on both V1in and V2in.
So here is the vector space stuff. Take the pair
of voltages at the input to be a vector in 2D
space (V1in,V2in) and the pair of voltages at the
output to also be a vector in 2D space (V1out,V2out).
This may be obvious and it may not be obvious, but
the output vector is just a linear transformation
of the input vector. This is profound. If true,
then all the truths that you know about vector
spaces and linear algebra must apply to these voltages.
So, if we have a linear vector space transformation,
then it probably has Eigen vectors. In particular,
if the the two lines of the pair are identical and
symmetrically placed with respect to the ground
conductor, then the Eigen vectors are the common mode
(V1in + V2in) and the differential mode (V1in - V2in).
Now, if the two lines are slightly different from
each other, the Eigen vectors (or Eigen modes) are
not exactly the common mode and the differential mode,
but often those are close enough that we just go ahead
and pretend that they are.
So if we put in a V1in, V2in pair of voltages, we
can decompose those two voltages into the common
mode and the differential mode, multiply by the
respective Eigen values (common mode gain and
differential mode gain) and we know what comes out.
I'll stop there. Let me know if this make sense.
Achilles: I wish my wish would not be granted.
< an undescribable event occurs >
Achilles: What happened? Where's my Genie?
Tortoise: Our context got restored incorrectly.
Achilles: What does that cryptic comment mean?
Tortoise: The system crashed.
To email me send to :
rb <my last name> AT ieee DOT org
