Skybuck Flying
Hello,
I read about how speakers work, and it appears there is a magnet/coil...
power is put on it... and the flow of power is reserved in quick
succession...
This makes the speakers go up and down/vibrate.
I believe switching/reversing flow of power might be bad for electronics
because of the hammering effect. Or maybe it just tears down the electronics
So I was thinking about a different design... (which might actually be worse
?) but ok... I am still going to describe it here... in case it's not
worse... and just to figure out if it has ever been tried before.
The idea for a new (?) speaker design goes as follows:
1. Instead of one magnet there would be two magnets.
One magnet to make the speaker go up.
One magnet to make the speaker go down.
2. Instead of reversing the flow of power the following would happen:
One cable to put power on the top magnet.
One cable to put power on the bottom magnet.
3. To make the speaker vibrate the following would happen:
3.1 To make the speaker go up:
Put power on top magnet.
Cut power on bottom magnet.
3.2 To make the speaker go down:
Cut power on top magnet.
Put power on bottom magnet.
This would create the vibrations needed to move the air.
The adventage could be the following:
1. I hope it's much easier to put power and cut power than it is to actually
reverse power ?
(The hope is that this will make the electronics easier, cheaper, less warm
and last longer).
2. Electricity flows into one direction which might prevent hammering ?
(This is where I am not sure... power on and power off... seems a lot like a
water facet going on and off and thus creating hammer effect ? oh-oh
Point 2 might be why this is a bad idea ?!?
Still I am interested in what you "experts" think of this idea, questions:
1. Has it been tried before ? If so what were the results ?
2. If not would it be possible ?
3. Would it be a good idea ?
Bye,
Skybuck.
succession...
reverse power ?
and last longer).
Bye,
Skybuck.
