Hi, im trying to get my head round ground loops and after some
verification of my limited understanding.
Looking at the driver of RS485, you measure the voltage between the
output_A and output_B. These go straight into another op-amp in the
diagram. I'm guessing the current from output_A cant flow back through
output_B becuase there are no means to do so (output_B goes into an
input)? What i dont understand is how it flows to the remote equipment
and back through the ground? We need to refernence a voltage point i
guess because a single line with some voltage on it is arbitary
correct? So they use ground, thats ok, but surely the ground is quite
resistive by the time you take into account the poor connections etc?
How does ethernet differ to the above? In diagrams i see output_A flow
through a transformer back to output_B... as it uses a transformer im
guessing the current can flow back through correct? Whats the name for
this type of input/output mechanisim?
Finally, how can there be a difference in potential between earth
points? I thought earth is earth??? Its obviously not becuase lots of
books mention ground loops i just dont fully understand yet.
Thanks in advance,
Chris
Thanks in advance,
Chris
