I have a rather simple circuit that controls heating elements. After testing each component, I find them all good except the r20 (47 ohms resistor And the diac.( the diac show a few ohms in each direction when tested with an ohm meter). I have replaced the 47 ohm resistor but don't have an idea of what diac would work in this circuit.
This is were my electronics stop and your help is needed.
This diac is the only component that I can't identify. I will add a circuit diagram I found that is wired exactly the same.
the component values are slightly different. they are:
r20 = 47 ohms
c24 = .224uf
triac = 56026
c23= .104uf
r19 = 1k ohms
vr4 = 0-500k ohms
diac = unkown
the load is a 240 volt heating element.
thanks for any help.
Rex
r20 = 47 ohms
c24 = .224uf
triac = 56026
c23= .104uf
r19 = 1k ohms
vr4 = 0-500k ohms
diac = unkown
Rex
