W. Watson said:
Any recommendations for a device to make the conversion mentioned in the
Subject line?
Converting from 50Hz to 60Hz is non-trivial (not difficult, but you need a
solid-state inverter to do so and these aren't found at your local mall).
However, most devices will be pretty happy on 120V, 60Hz and this is easy to
obtain with just a transformer, which you *can* find at your local mall.
Anything with a switching power supply will be perfectly happy with this
(e.g., PCs, LCD TVs, most battery chargers, etc.). Depending on the motor
design, tools may run more slowly and tend to get a little hotter, but unless
you're planning to make continuous use of high-power tools, practically
speaking this isn't a problem. Some clocks that rely on the frequency of the
AC line will, of course, run slow, but they won't be damaged.
If you have purely *resistive* loads such as hair dryers (with small universal
motors are OK), lamps, etc., you can find what are essentially just diodes at
a travel store. These converters are cheap (e.g., 1500W versions are <$10 in
many cases), but won't work for anything with a decent-sized transformer or
motor in it. Most switching power supplies are OK with them (most switching
power supplies really don't care that much at all about the exact waveform at
the input).
There are "hybrid" adapters with the diode and a small transformer... 1500W
load capacity using the diode, 50W or so load capacity using the transformer.
I've never quite figured out what the intended audience for these is --
perhaps people with old electric razors or something where the diode approach
just makes it buzz?
At most I would expect to be charging batteries for camera equipment.
Does your charger have a switching power supply? If so, first check to see if
it's a universal input voltage (90-240VAC) -- it may well be and all you need
is a plug adapter just so that you can physically connect it to the Chilean
mains.
---Joel
