desperate for solution
A First Alert Wal Mart, water sensor, similar to the smoke detector, operates off 9 volt batt.
The unit comes with about a 6ft. lead with a sensor, thus when the sensor gets wet the alarm sounds off. I have about 6 working units in our houseboat, For the most part they are under the floor inside the hull and I cant hear them if topside and the hatch lid is closed.
Id like input if I can add some type of sounding device attach it to these units I have 4 of them under the hull......and get this sounding device topside.
Ideally Id like one alarm type sounding device I could place in our living area,
Should I get a alarm its not important which unit is going off but lets me know there is incoming water and I need to get it stopped.
2nd option possibly
If I still have your attention would I be able to add as much as 20 ft of wire to each unit an just hide the actual alarm part topside inside a cabinet (should my first part be to complicated)
thanks for any input. excuse my chopy description
I would suggest that you can probably extend the cable significantly.
Do it to a single unit (make it the longest you'll expect to need) and then test it to make sure it reliably detects water.
I expect there won't be a problem.
Similar threads
F
Replies
3
Views
926
JeffM
Replies
2
Views
1K
James Finlan
Replies
26
Views
3K
Terry Pinnell
