jason
I am a design student at Pratt Institute in Brooklyn. I have a
project/prototype due this Thursday and wanted to see if this is
something you (or someone you know) could be able to help me out with.
It doesn't have to look great, just work. I can design the housing (if
necessary) around whatever the outcome is
Essentially, this would be a motion detector hack.
The parameters around what I need to be built:
- an occupancy sensor that screws into and is powered by an existing
medium-base light socket -- the bulb then screws into the sensor
- if the sensor doesn't detect someone, the light runs at 80% of its
maximum output
- when the sensor detects someone, the light output increases to full
capacity (i would like this to be a smooth transition/fade, instead of
on/off)
- 15-seconds (adjustable if possible) after area is unoccupied, the
light decreases back to 20%
If you need a visual representation, please let me know. I will be more
than happy to pay for parts and materials, as well as a reasonable rate
for labor. Or if you would like to barter, I am an award-winning
graphic/web designer and can help you out in that area.
Thanks in advance!
Jason
maximum output
on/off)
Thanks in advance!
Jason
