G
Geoff
http://i251.photobucket.com/albums/gg302/triode101/sink.jpg
This circuit is to drive a scientific lamp which is low pressure
neon of strike volts 600V and typ run volts of about 200V. The
design intent is DC current from 0 to 60mA. This circuit
traditionally runs to about 30mA with no problem and is well
proven at these currents. Normally it is not darlington pair but
it is something I have tried..
The trouble I have with this circuit is that at above currents
of about 35-40mA the lamp starts to flicker indicating a higher
current than is dialed in by the pot. An oscilloscope at the
opamp output confirms that at the point where it starts to
flicker, the loop starts to try to lower the current since the
opamp output volts drops. The onset can be made to be a periodic
dip (tens of hz dip about a volt) before the lamp begins to
flicker. When the lamp flickers on and off more severely, the
opamp tries to go negative to compensate. This to me shows that
the output transistor is conducting, not the failure of the loop
control.. I have played around with the drive impedance, ie
with/without the 1k base resistor. The point of flicker can be
less severe with the resistor, or latches hard without. Maybe
the VCEO spec is being stretched here. I have tried a variac and
reduced the volts to about 580V, still does it but onset is
higher current (50mA). I have tried a BUL 416 transistor also. I
might just be applying too much voltage, but I can't see why,
might have to look at the op curves a bit harder. Maybe I could
use a MOSFET or IGBT.
