Steve
Well, looking for ideas would be more accurate as I've currently run out of
them!
I need to design a small, single cell, battery powered inverter to produce a
very approximate (within say 10%) constant 2A into a resistive load. The
load may vary such that the cct needs to deliver from about 1.5 to 2.5v. The
inverter final output could happily be AC as the load is resistive.
The particular difficulties I see are that:-
1. The supply is a single rechargeable cell of only a nominal 1.2v which
rules out many of the usual IC SMPS control devices.
2. The unit should need no user power switch and only consume a maximum
of perhaps a few 100uA when the load is disconnected.
Given the low current accuracy requirement, I've been thinking along the
lines of a self oscillating discrete design with a periodic trigger kick that
works when the load is connected. I'm hoping for some suggestions on
obtaining the constant current characteristic. I know I could just produce a
classic DC output design with I feedback, but was hoping to avoid the extra
complexity (cost) and losses (battery life) involved in the rectification.
I've been perusing my old discrete design handbooks for ideas and have drawn
a blank, rather like my brain at present.
I'm currently enquiring whether it would be possible to make the supply a 2
cell battery, as I already have a design that could be modified to be
suitable.
If that avenue fails, have any of you come across anything like this, or have
possible circuit configurations to consider?
them!
suitable.
