Hi All!
First I'd like to say thanks for using my program! I'm aware of the glitches you mentioned, but couldn't find any "cleaner" way to do it,
so that's just kind of how it is. I haven't gotten "bored" with the project, I just got it working to a point where it was working
pretty good and decided to leave it like that for a while. I'd like to add LTE to it soon, so I may get back to work on it sometime this year.
PS- It's just me so it's "developer" in the singular term
I think we found the problem
LG makes really bad GSM/UMTS phones (their CDMA is a little better). If you want a budget GSM phone
with good reception, get a Nokia, or Motorola. Otherwise look into a repeater, or femtocell (but you'd have to get an
AT&T subscription for that to happen I believe)
Thanks again for using my app. I actually built in in 2008-2009 as an experiment on my Nokia N95 phone. I built it to use for myself
originally, but then decided it would be cool to open it up to the public to see everyone elses coverage plots as well. It's
coming up on 1 million points soon, I'm glad to see people all over the world have found it useful for various purposes
The app is free and the advertising barely pays for the server, so I'm definitely not in it for the money
I am a cellular network engineer, so it's an interest of mine.
SNR is "Signal to Noise Ratio" and tells you how "clean" the signal is (ie: if it has alot of interference or not).
The "Power control" in the phone and base station determines how much the transmit level should be. SNR plays a factor, but signal loss does as well.
RSSI (Receive Signal Strength Indication) is what's shown in the Cellumap app. That's the total received signal power, interference and all.
That's a nice plot, what open source software did you use to make that? Most simulation software (like TEMS) is
usually very expensive. Also, how do you determine what transmit power and antenna gain to use?
