Hey all,
Hoping someone knowledgeable about this type of equipment can help, i'm at my wit's end!
I have replaced the belt to allow the CD tray to open and close, which now seems to be working fine.
However, when a CD is fed in, it spins up for 2-3 seconds, and then spins the other way for 2-3 seconds, endlessly.
I've read online that the CD spinning up is a good sign, meaning that the lens is OK (or at least recognizes a CD), so hopefully that's good news!
Now I have investigated a bit further, pulled out my multimeter and can see that I'm getting alternating +5V, -5Vtension voltage at the cable end the spindle motor is plugged in, which seems coherent with the behavior.
I've also managed to find a service manual for the thing (in German of course, why make it easy?), and have traced the connection to the servo chip, at which I am getting +2V, -2V, also alternating...
So something is wrong before that stage but I'm just not expert enough to understand where this might be coming from...
Hopefully someone can help!
I've got the service manual PDF if someone thinks they can decipher the thing. I'll keep trying in the meantime.
Video of the issue:
Denon DCD-800
Thank for any help you could provide
Antoine.
[mod edit: replaced tension by the common term voltage]
Video of the issue:
Denon DCD-800
Antoine.
