'Deliberate' lifespan of modem/routers?
I hope these are not too silly questions but are modem/routers made to last for a short lifespan; and what electronic component goes first on them? Does leaving a modem/router permanently on shorten its lifespan?
A lot of today's electronic gizmos are squeezed into small housings and components inside can get rather warm. Electrolytic capacitors are the prime candidate for failure and have rated lifetimes typically of just a few thousand hours. Elevated temperatures shorten their actual working life.
A lot of today's electronic gizmos are squeezed small housings and components inside can get rather warm. Electrolytic capacitors are the prime candidate for failure and have rated lifetimes typically of just a few thousand hours. Elevated temperatures shorten their actual working life.
Thank you, Alec. So it is best to switch off the router after the day's use.
I find the lifespan issue particularly affects passively cooled consumer grade networking gear, modems, switches and routers. Modems I have the best luck with, though I usually buy Motorola/Arris which tend to be about the best consumer grade build you can get.
Routers and switches on the other hand, tend to first blow the electrolytic capacitors in the switch, then eventually the output electrolytic in the wall AC/DC adapter, or in some cases if you don't surge protect everything including all network gear and the client systems, a power surge will take out one port at a time.
These days, low port count (8 or fewer), consumer grade gigabit switches are fairly inexpensive so I just run them 24/7 as-is, but routers I also run 24/7 but do a bit more... voiding the warranty in the process.
1) Replace all electrolytic capacitors in the router with solid/polymer types. I do not wait until a failure to do this. I do it before first deployed and have never had a single solid cap fail, which it used to be fairly routine that the electrolytic caps would fail after roughly 5 years of 24/7 service.
2) Vent holes. Pop the casing off, lay down some masking tape on it, use a ruler to draw a grid where you want to put vent holes. Throw the casing on a drill press to make evenly spaced, true holes. chamfer the holes on both sides to get rid of plastic remnants.
In some cases it can make for an interesting visual effect of the front indicator LED light coming out the top.
  • Like
Reactions: Ian
Hi Dave, I really appreciate your and others input. I wish I was an electronic boffin:-(
I recently repaired my own router (Netgear) that had two duff capacitors in it. It had been running 24/7 for over 4 years!
Planned obsolescence can be either ending support, changes in technology (improvements) or by cost-cutting measures resulting in lower quality components being used.
Whether or not this is 'deliberate' is debatable but if you want the best/fastest etc you're inevitably stuck with the upgrade process which itself wouldn't happen without consumer purchases.
