G
George
This isn't really a design question as such, but I hope someone will
have an idea about it.
I have an Canon Elura 100 miniDV camcorder, which has automatic gain
control on audio. I'm sure Canon thought they were doing a good
thing with this, but it causes motor noise to be picked up quite
noticeably during times when the audio level is low and the gain is
ramped up to the maximum.
This model also has an external mic input, but the mic needs to be a
"self-powered" electret. So, I built a little amp for that, powered
by a 9V battery. Unfortunately, it appears the AGC is still there.
And while I don't get motor noise, it appears the amplifiers in the
camera aren't exactly low-noise, so when they crank up looking for
something to hear, Or it may be noise from my amp that gets
amplified, but I don't hear that when I use this setup on the
computer mic input.
Anyway, since I've already built this amplifier, I just wondered if
there's anything I could add to its output that wouldn't be audible
to humans, but would fake out the camera AGC. Or maybe center the
output level a bit above ground - well, ok, that's not likely to
work assuming the camera inputs go through capacitors.
Well, I don't have my hopes up on this, but just thought I would ask
in case there was a solution.
Of course I could record the audio separately on another device, but
that's a lot of trouble since the streams would have to be synced at
some point.
Thanks for any ideas.
computer mic input.
some point.
