I am about to make a circuit to deter deer from eating some plants. I plan to make the circuit activated:
A: when dark (this is when the deer come)
and
B: when PIR sensor activated (the PIR sensor I am planning on using senses up to 30 ft away!)
Planned:
Stage 1 creation:
option 1:senses dark and PIR activation, output to buzzer
option 2:" " output to lights
option 3:" " output to motor
Stage 2 charging:
Because the circuit is only needed at night this leaves open the possibility for solar charging, I will however need to be a bit more experienced before I can create a system to stop overcharging.
I am going to make it output to a loud buzzer to begin with, hopefully this may scare them however if this is ineffective I am going to have to use bright, flashing lights or if this does not work I will try movement output.
5 July 2014 to ---- : planning stages and circuit diagram
6 July update: Logic sorted
14 July update: Circuit diagram drawn- few specs
and
Planned:
Stage 1 creation:
Stage 2 charging:
