Brad
Regarding Emerson (Funai) LCD TV model EWL20S5 (mfg 03/06):
Symptom: TV won't turn on.
Now that I finally got the SM, I was able to perform tests.
The 5.5V source reads 1.8V. I replaced C635 470/10, which read around
340uf on tester, with a 470/16 105deg., but that didn't fix the problem. I
tested many components and ruled out a heavy load on power supply (SMPS).
Raw B+ is fine. There are other components I have to test, but to save time,
has anyone serviced this model or a similar model with the same symptom?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
