Model: Schumacher SSC-1500A It has 3 power settings, 2 amps, 6 amps, and 15 amps
Symptoms: Not fully charging batteries anymore. It will still partially charge batteries, but not all the way.
The charger turns on and the display turns on also.
I opened up the case and there was a capacitor bulged so I replaced it, but the charger still doesn't work. I replaced the one on the second picture right next to the big red/black cable.
I do have an esr capacitor meter and I'll have to check to see if my multimeters at home have a diode setting.
I'm including pictures of the circuit boards.
Attached to the heat sinks (assuming they're heat sinks, the tall long metal pieces) are what appear to be transistors)
Could someone please help me figure out what's wrong with this so I can fix it?
This first picture is of the circuit board on the display. The other pictures of circuit boards are of the main one inside.
Thanks.
Thanks.
