Didi said:
Actually most if not all about length matching in these application
notes
is just scaremongering. At apr. 150 pS/inch, doing even a 1/2" inch
length
mismatch will add 75 pS of skew - hardly an issue at 200 MHz DDR.
To relate to another recent thread here, sometimes even the plain
arithmetics can be fairly helpful...
Dimiter
Hi Dimiter
Well, it depends.
At 200MHz, (400MT/s), the maximal data window is 2.5nS. When one
subtracts a typical 0.7nS for the DDR controller skew (that depends on
the controller, of course) and an access window of +/- 0.7nS, subtract
the DQ jitter [and a number of other parameters] and board jitter
(mostly deterministic) and that 75pS is no longer a small matter.
The OP can get a lot of free support information here:
http://www.micron.com/support/designsupport/tools/ddrtoolbox/ddrtoolbox.aspx
Although one _may_ get away with 0.5 inch mismatch, it probably won't be
guaranteed timing across temperature and parts. I like to design for
guaranteed margins. The last time I designed DDR onto a board (not
DIMM/SODIMM) I ended up with 120pS of guaranteed margin. SODIMM can be
just as tight.
For the OP - it's not just the DQ set - the timing budget has to be set
against the Clock pair -> Address/control, Clock pair -> DQ set. As the
strobes are driven from the memory diring a write cycle, you have to
subtract the outbound time from your receive data window. I strongly
suggest you read a typical datasheet and the file 'Plat7Justin.pdf' on
the page referenced, at the very least.
Cheers
PeteS
Cheers
PeteS
