I have a microprocessor with built in DCDC converter. We need to provide inductor and output capacitors externally at the respective pins of the processor. The regulated o/p from the internal DCDC converter is for internal core and IO as well as for external peripherals. The manufacturer recommends using 0.01uf, 0.1uf, 1uf and 33uf at the DCDC output pin. What should be the order of placement of these o/p capacitors on the board? 0.01uf close to the pin and 33uf away or the other way? The current from the o/P pin is both ways. i.e goes internal to the IC as well as goes out of the pin to the other peripherals on the board.
-bjnk
-bjnk
