Hi ALL!
I have this Omron Blood Pressure machine that I use on a daley basis. I've had it for awhile, the cheap plastic leed has twisted itself off, right at the base of the plug in AC to DC low voltage Xfer.
I just repaired it, maybe for the last time, because I'm down to hairs to solder on to.
The question is, as with many of you, I have plenty of AC-to-low-voltage-DC power supplies, hanging around doing nothing!
The Omron power supply puts of 6V DC, 500 ma.
The power supply I have with a good leed puts out 9VDC, at 500 ma. The qustions is, will that kill the BP machine? Or will it ONLY use what it needs, and the extra 3VDC won't matter ?
Many thanks, ElecTed II
