W
W. Watson
I need some trick to properly size a DC plug (female) into the DC socket (female) on
an electronics box. The adapter sent to me was too small a diameter to fit over the
socket tip, so I cut off the plug, and mounted an N type from Radio Shack. I did a
make shift job, because the DC cord was too big for the RS plug. Eventually, the plug
broke loose. I asked a friend to pick up a plug at an electronic store in Sacramento,
but she got a plug, although, the wire will slip into it well, the size of the inner
cylinder is too big to make a connection with the pin in the socket. Is there some
clever trick I can use to make the cylinder size smaller?
Wayne T. Watson (121.015 Deg. W, 39.262 Deg. N, 2,701 feet, Nevada City, CA)
-- GMT-8 hr std. time, RJ Rcvr 39° 8' 0" N, 121° 1' 0" W
"Don't you just hate it when someone leaves their call back phone
number at 100 digits a second? And worse. At the end of a long message."
-- Andy Rooney (in disguise)
Web Page: <home.earthlink.net/~mtnviews>
sierra_mtnview -at- earthlink -dot- net
Imaginarium Museum: <home.earthlink.net/~mtnviews/imaginarium.html>
