Will the current rating of the power source affects the system?
This is how I computed the resistor rating i used:
(Voltage Source - Operating voltage of the LED)/Operating Current of the LED = Resistance in Ohms
This is the actual computation:
Given:
Source: 12 volts wet cell
number of LEDs: 6
color of LED: Yellow
ampere rating of one LED: 20 mA
voltage rating of one LED: 2 Volts
(12.2 Volts - 6 x 2 Volts)/20mA = 10ohms
my question is what will be the effect of the different input current since it's not part of the computation for the resistor..
I will use a 12.2 Volts with 6A input rating (WET CELL)... the 6 Amperes is so strong for the circuit, so, is it safe? or it has no effect whether i use 12.2 volts with 3 Amperes or 12.2 volts with 6 Amperes...
TYVM
Given:
number of LEDs: 6
TYVM
