Stretto
Is the only issue with DC coupling op amp stages the offset error? If so, in
general, is this a big problem with modern op amps?
How well does offset nulling work?
Are op amps without nulling capabilities meant for AC coupling?
Is the issue mainly a problem with high gain? Obviously high gain will
increase the DC offset but is it something that should be worried about for
low gain too?
Does the CMRR reduces the DC offset significantly? Higher CMRR's will mean
less DC offset? Can I expect by using simple circuit design(stuff found in
basic textbooks) that the CMRR will reduce the DC offset by it's rated
value? -120dB CMRR will reduce any DC offset by about 120db?
The real issue with DC offsets has to do with the finite voltage swing
capabilities? If we amplify the DC offset too much then the op amp cannot
amplify the AC signals that may be outside than the rails? So DC offset
problems simply reduce the headroom?
low gain too?
