Datasheet wanted for Q165A diode
Hello, I have a Panasonic TV which does not switch on. The power supply board has two diodes that appear short circuit (<1ohm either way). They are labelled Q165A and I suspect they may be transient suppression diodes as they are part of the transformer circuit. Problem is are these common cathode, common anode or what? Unless I can find out I can't really fix the board. I've not found a circuit diagram either. PCB reference is TNPA5806 which seems to be used in a number of Panasonic Viera TVs.
Any ideas appreciated.
bertus
Hello,
Is the Q165A written on the part or the board?
I can not find anything for Q165A.
Where is the part on the board.
Bertus
Hi Bertus,
Thanks for replying.
The part is on the back of the board under the large transformer to the left of the board picture. The part is marked on the case Q165A, nothing else. I think the package is DPAK, problem is the tab could be cathode or anode it may be one or two diodes internally I just can't even guess.
Roger
...oh and the PCB is marked D7408 and D7409 (two diodes appear shorted) that's how I figured it was a diode of some sorts.
Roger
bertus
Hello,
I see more of those diodes on the back.
Unfortunately the markings can not be read.
I have used the pictures from this page to show:
https://www.ebay.com/c/1271470258
What is the type number of the TV?
Perhaps we can find a manual with more info.
Bertus
The board is similar to mine but my D7413 and D7412 are not populated (maybe a lower power rated board).
In the photo you've attached all the diodes look fried.
Hi Martin,
Thanks, that's great, I think you've cracked it. I found the circuit diagram for a similar PCB late last night (TNPA5808) and the circuit diagram symbol showed common cathode diodes on the transformer output windings (see attached filename 7 should be a 5). That ties in with the datasheet you have found.
Many thanks to both yourself and Bertie for helping.
Roger
