Data for japanese diodes and non-transistor devices?
Chaos Master
Where can I find data on japanese diodes and other Japanese devices? Transistors
are easy, just type 'japanese transistor data' on Google...
Any on-line cross-reference sites?
Getting replacements from NTE is near out of luck, as I am in Brazil.
Thanks!!!!
W
Watson A.Name \Watt Sun - the Dark Remover\
Thanks!!!!
Most diodes break down into a few groups. There are rectifiers, signal
diodes, zeners, and germanium signal diodes, to name a few. If you like
NTE, well, one size fits all, so to speak. Like 1N914 or 1N4148 for
signal diodes, 1N4005 or similar for 1A rectifiers, and of course zeners
are whatever value of voltage you need. 1N4728 or upwards, I believe
for 1 watters. Just about any Ge diode could be replaced by a 1N270.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
F
o
d
d
e
r
f
o
r
s
t
u
p
i
d
n
o
t
e
n
o
u
g
h
i
n
c
l
u
d
e
d
t
e
x
t
m
s
g
Jeff
Thanks!!!!
Japanise diode manual, transistor manual should be available, the sub manual
is poor choices in many cases.
Try MCM electronics.
Lots of fun figuring out the diode manual listings!
Jeff
Chaos Master
In an arcane spellbook written by the priests, labeled 'Posts of
sci.electronics.components' I found a message from "Watson A.Name \"Watt Sun -
the Dark Remover\"" <[email protected]>["Watson A.Name \"Watt Sun - the Dark
Thanks for the tip. Here in Brazil it's rather common to find stuff imported
from Japan (generally audio stuff, AFAIK) and parts are hard to come by.
