Jamie
This is the scenario:
Lets say we have a catenary arm with a pot
on it that monitors the catenary position. This
arm has a chive (roller) where we wrap wire around
it to serve as a pully. As the wire starts to be pulled
away from the machine, this arm will move thus moving the
POT which signals the drive to give the reel of wire a
push to maintain the catenary arm in a desired position.
Now, we use regen drives for this application (Penta KB series)
to be exact, and here is the problem..
The load on the shaft is heavy and what happens is when the
catenary arm moves in position to signal the drive, there may be
a delay of response due to the extra swing load of weight and
thus the arm might end up in a position where high bias voltage is
now at its point and when the shaft finally gets going in the other
direction, it goes to fast! And thus, this extra weight generates
a lot of it's own momentum. (Swing load).
This is what i want to know before i go and build it. cause if
it's on the market i would rather buy it.
I need to detect the speed of which the catenary arm is moving,
not the reel speed! I do not want to employ encoders on the shaft
because of expense reasons.
It must generate a negative response to what the POT wants the
drive to do as the POT starts to change position and as soon as the pot
stops, the POT's real signal will be reported at the position it is
currently in.
I need this type of control to not allow the drive to accelerate so
fast that the catenary arm whiplashes.
My thoughts on this for ideal thinking, is something like a voltage
follower that mirrors the POT's signal, a capacitive system will create
an inhibiting signal as the voltage changes but not inhibit when the
voltage from the POT is stable or changing very slowly.
The end results is, the POT's signal to the drive will change slowly
to get the catenary arm into position but not too slow where it will
cause it to stall in position. Lead, Lags, Delays etc found on most
Dancer and drive controls does not do what i need, due to the fact that
a lot of these circuits tend to memorize last time effects and just
compound the problem.
I hope i have made this clear enough, if there something on the market
in like a mini board form that runs off lets say the REF's supply
voltage of around 10 or 15 volts that conditions the signal it would be
nice..
Other wise, i will have to make my own debouncer circuit..
P.S.
we have already tried outboard dancer boards like the old Reflex series
and the drive it self has an extensive set of controls which serve their
purpose just fine how ever, none of them give me this kind of control.
I have seen this in eurotherm digital drives where the max speed can
be retarded by the rate in which the POT value changes. The faster the
POT changes, the slower the drive/motor attempts to go.
but in our case, we are using non-digital drives ( a lot of them) with
Armature feed back!..
Thanks for any input.
currently in.
nice..
P.S.
