Tony said:
In <
[email protected]>,
You could be right about the windings rattling, it's more of a hissing
noise than a whine.
Depending on your hearing, you may not be able to tell the difference
between 15khz hiss and whine. But if it's really hissing, sounds like
you may have high voltage corona. Blow the dust out of it. If you
smoke, you've probably got gunk all over the inside that will be nearly
impossible to get off.
I've seen ceramic caps that make very efficient sound generators in this
frequency range. They're so stiff and well coupled to the board that
there ain't much you can do except change them to some type that's not
piezoelectric.
I suppose I could see if anything like this is going to work by poking
them with something like the rubber on the end of a pencil while they're
making the noise... I heard you have to be a bit careful about what you
use on them, some materials are corrosive. I definitely don't want to
replace the coils altogether.
Don't go poking around in there with a pencil. Use something completely
insulating, plastic, phenolic rod, anything but a pencil.
mike
Return address is VALID.
Bunch of stuff For Sale and Wanted at the link below.
Toshiba & Compaq LiIon Batteries, Test Equipment
Honda CB-125S $800 in PDX
Yaesu FTV901R Transverter, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
