I
Inspar8r
I have a question about a design problem i need to address.
I designed and built a set of LED taillights for my car. Obviously,
the LEDs draw significantly less than a standard bulb.
The problem is, there is a circuit that is designed to monitor the
bulbs, and illuminates a light in the cluster when the bulb fails.
Right now, it thinks my LEDs are failed bulbs.
I am not satisfied or comfortable with wiring up parallel 6© 10W
resistors for the taillights and 47© 25W resistors for the brake
light circuits just to mimick the standard bulb (as well as dissipate
almost 1A of current as heat every time the brakes are applied).
Removing the bulb is not an option either. Most have told me that b/c
they are LEDs, i don't need to monitor the circuit, but i'd like to
anyway (you never know)...
The failure sensor is a CURRENT sensing device, and according to the
schematic, uses an OR-gate that signals a npn transistor that powers
the warning light. The OR-gate is fed by 2 unidentified "boxes" (i'm
guessing IC's). I think the OR-gate is there to allow the failure
sensor to monitor the tails both when the car is in ACC and when
started.
My question is, where can i find schematics on IC current sensors that
i can tailor to my needs to build my own sensor and just bypass the
stock sensor?
If I knew what those unknown boxes where, i would modify the stock box
to "look" for less current.
Any ideas...
Posted at: http://www.GroupSrv.com
Check: http://wwww.HotCodecs.com
started.
stock sensor?
Any ideas...
