I'd like to measure the current which a motor-controller is applying to a motor.
Current range is [-2A,+2A].
I imagine either
(a) "map" this current into 0-4V, which I can read with my ADC, or
(b) map this into a smaller output range, say [-0.02V,+0.02V], and I can feed my instrumentation-amplifier to map that into an ADC -appropriate range,say [0.1V,2.4V].
If I'm using a shunt resistor then I suppose that leads me to (b) over (a).
The motor-controller outputs a differential motor driving voltage.
So, whichever motor wire that I choose to splice a shunt resistor into,
the common-mode voltage might be as much as +12V when driving the motor oneway, and -12V when driving the other way.
(that is, the Vdiff applied to the motor can be in [-24,+24]).
How would you sense the current?
I searched "High-Side Current Sensing" and found an Analog Devices AD8210,
but that device, and its family of devices, permit common-mode voltage in range of [-2V,+65V].
So sounds great when I'm driving one direction, but i'll destroy it when reversing?
Or should I wind a coil of wire around a motor lead and try to sense it inductively? Then maybe I could ground one end of that coil and come away with a [-0.02V,+0.02V] signal that and I would calibrate it against a DMM. Maybe I'll reseach inductive current probes and see what I find...
Thanks for any pointers, advice, and success stories.
John
I imagine either
John
